Ir para o conteúdo principal
Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement
O que você precisa
  1. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Backplate: passo 1, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Backplate: passo 1, imagem 2 %32
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: passo 2, imagem 1 %32
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Battery: passo 3, imagem 1 %32
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Speaker: passo 5, imagem 1 %32
    • There are two speakers which are found on the lower left and right side of the laptop, beside the battery.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: passo 6, imagem 1 %32 Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: passo 6, imagem 2 %32 Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: passo 6, imagem 3 %32
    • Remove the screws of the motherboard to disconnect the motherboard from the speakers using a Phillips #0 screwdriver.
  7. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: passo 7, imagem 1 %32
    • Remove the 4 mm screw with the Phillips #000 screwdriver and remove the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Alexander Nwonye
Membro desde: 03/21/19
127 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 108
