Ir para o conteúdo principal
Samsung ATIV Book 4 Screen Replacement
O que você precisa
  1. Samsung ATIV Book 4 Screen Replacement, Screen: passo 1, imagem 1 %32 Samsung ATIV Book 4 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: passo 2, imagem 1 %32
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: passo 3, imagem 1 %32
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: passo 4, imagem 1 %32
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
Conclusão
Daniel
Membro desde: 03/19/15
342 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-7, Lauer Spring 2015 Membro de Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
Membros da 2
Autoria de 6 guias
Um comentário
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 3,396
