Ir para o conteúdo principal
Samsung ATIV Book 4 Mouse Pad Replacement
O que você precisa
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: passo 1, imagem 1 %32 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: passo 1, imagem 2 %32 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: passo 1, imagem 3 %32
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: passo 2, imagem 1 %32
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: passo 3, imagem 1 %32 Samsung ATIV Book 4 Mouse Pad Replacement: passo 3, imagem 2 %32
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 4 Mouse Pad Replacement: passo 4, imagem 2 %32
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
Conclusão
Daniel
Membro desde: 03/19/15
342 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-7, Lauer Spring 2015 Membro de Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,089
