Ir para o conteúdo principal
Samsung ASV09PSBAN Circuit Board Replacement
O que você precisa
  1. Samsung ASV09PSBAN Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
    • Turn off the power from the circuit breaker.
  2. Samsung ASV09PSBAN Circuit Board Replacement: passo 2, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 2, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 2, imagem 3 %32
    • Carefully remove the front grille panel by placing your hands at the top of the air intake cover.
  3. Samsung ASV09PSBAN Circuit Board Replacement: passo 3, imagem 1 %32
    • Use your hands to remove the air filters.
    • Clean the air intake screen with a vacuum if necessary.
  4. Samsung ASV09PSBAN Circuit Board Replacement: passo 4, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 4, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 4, imagem 3 %32
    • Remove the screw from the small panel on the right side.
    • Remove the cover.
  5. Samsung ASV09PSBAN Circuit Board Replacement: passo 5, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 5, imagem 2 %32
    • Disconnect the black wire from the unit.
  6. Samsung ASV09PSBAN Circuit Board Replacement: passo 6, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 6, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 6, imagem 3 %32
    • Disconnect the two parts of the white wire.
  7. Samsung ASV09PSBAN Circuit Board Replacement: passo 7, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 7, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 7, imagem 3 %32
    • Remove two screws from each side of the front panel.
  8. Samsung ASV09PSBAN Circuit Board Replacement: passo 8, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 8, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 8, imagem 3 %32
    • Completely remove the front panel.
    • If you can not remove it easily, use a spudger to carefully pry it open.
  9. Samsung ASV09PSBAN Circuit Board Replacement: passo 9, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 9, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 9, imagem 3 %32
    • Remove the old circuit board from the three notches holding it in place.
    • Thread the bundled white wire through the slot and remove the circuit board completely from the unit.
    • Install a new circuit board.
  10. Samsung ASV09PSBAN Circuit Board Replacement: passo 10, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 10, imagem 2 %32
    • Reinstall the front panel.
    • Replace the two screws on each side of the front panel.
  11. Samsung ASV09PSBAN Circuit Board Replacement: passo 11, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 11, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 11, imagem 3 %32
    • Reconnect the white wires.
    • Thread the black wire through the slots.
  12. Samsung ASV09PSBAN Circuit Board Replacement: passo 12, imagem 1 %32
    • Reinstall the small cover.
  13. Samsung ASV09PSBAN Circuit Board Replacement: passo 13, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 13, imagem 2 %32
    • Reinstall the filter.
  14. Samsung ASV09PSBAN Circuit Board Replacement: passo 14, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 14, imagem 2 %32
    • Restore the power to check if the unit is functioning.
  15. Samsung ASV09PSBAN Circuit Board Replacement: passo 15, imagem 1 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 15, imagem 2 %32 Samsung ASV09PSBAN Circuit Board Replacement: passo 15, imagem 3 %32
    • If the unit is functioning, turn the fan off, and reinstall the front grille panel.
    • At the end, you can turn it on again.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jenny
Membro desde: 03/22/21
269 Reputação
Autoria de 1 guia
Equipe
Um comentário
I am having problem like different way, if I set temperature from 23'C to 17'C than only outdoor unit (compressor unit) start working. Even though it's started, but I feel the temperature like 29 'C only. What will be the problem? Suggest me..
Kishore Kumar S - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 46
Últimos 30 dias: 103
Duração total: 1,860
