Ir para o conteúdo principal
Samsung 500C ChromeBook Battery Replacement
O que você precisa
  1. Samsung 500C ChromeBook Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung 500C ChromeBook Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: passo 2, imagem 1 %32 Samsung 500C ChromeBook Battery Replacement: passo 2, imagem 2 %32 Samsung 500C ChromeBook Battery Replacement: passo 2, imagem 3 %32
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Conclusão
3 outras pessoas executaram este guia.
Equipe
Michigan Tech, Team 1-2, Lauer Spring 2014 Membro de Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
Membros da 3
Autoria de 10 guias
3 comentários
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Responder
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Responder
Don't show my NAME
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 3,234
