Ir para o conteúdo principal
Samsung 27E510C Motherboard Replacement
O que você precisa
  1. Samsung 27E510C Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Samsung 27E510C Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Samsung 27E510C Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Motherboard Replacement: passo 2, imagem 1 %32 Samsung 27E510C Motherboard Replacement: passo 2, imagem 2 %32
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C Motherboard Replacement: passo 5, imagem 1 %32 Samsung 27E510C Motherboard Replacement: passo 5, imagem 2 %32 Samsung 27E510C Motherboard Replacement: passo 5, imagem 3 %32
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C Motherboard Replacement: passo 6, imagem 1 %32 Samsung 27E510C Motherboard Replacement: passo 6, imagem 2 %32 Samsung 27E510C Motherboard Replacement: passo 6, imagem 3 %32
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C Motherboard Replacement: passo 7, imagem 1 %32 Samsung 27E510C Motherboard Replacement: passo 7, imagem 2 %32
    • Using both hands, lift the board off of the monitor body by the motherboards base.
Conclusão
Uma outra pessoa concluiu este guia.
giggythore
Membro desde: 10/14/17
366 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S9-G1, Banghart Fall 2017 Membro de Cal Poly, Team S9-G1, Banghart Fall 2017
CPSU-BANGHART-F17S9G1
Membros da 6
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 1,874
