Introdução
The JOG button is used to control monitor functions like volume, brightness, and contrast. Common issues of this feature include the button sticking and the control stick breaking off.
O que você precisa
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Ferramenta utilizada neste passo:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Conclusão
