Ir para o conteúdo principal
Samsung 27E510C NAV Button Replacement
O que você precisa
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: passo 1, imagem 1 %32 Samsung 27E510C  NAV Button Replacement, Back Panel: passo 1, imagem 2 %32 Samsung 27E510C  NAV Button Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: passo 2, imagem 1 %32 Samsung 27E510C  NAV Button Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: passo 3, imagem 1 %32
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: passo 4, imagem 1 %32
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: passo 5, imagem 1 %32 Samsung 27E510C  NAV Button Replacement: passo 5, imagem 2 %32
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: passo 6, imagem 1 %32
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: passo 7, imagem 1 %32 Samsung 27E510C  NAV Button Replacement: passo 7, imagem 2 %32 Samsung 27E510C  NAV Button Replacement: passo 7, imagem 3 %32
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
Conclusão
giggythore
Membro desde: 10/14/17
376 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 824
