Ir para o conteúdo principal
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
O que você precisa
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: passo 1, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: passo 1, imagem 2 %32
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 2, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 2, imagem 2 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 2, imagem 3 %32
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 3, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 3, imagem 2 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 3, imagem 3 %32
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: passo 4, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: passo 4, imagem 2 %32
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 5, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 5, imagem 2 %32
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 6, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 6, imagem 2 %32
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 7, imagem 1 %32 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 7, imagem 2 %32
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 8, imagem 1 %32
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: passo 9, imagem 1 %32
    • Remove the home button by sliding it to the left or right while pulling up.
Conclusão
Uma outra pessoa concluiu este guia.
Guneet Bawa
Membro desde: 04/12/18
688 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G5, Liner Spring 2018 Membro de UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 2,003
