Introdução
Use this guide to replace a damaged Samsonite luggage wheel.
A damaged wheel may stick, causing the suitcase to veer off course, or preventing the suitcase from moving. A replacement wheel will help you fix the problem.
Step 1 will help you ensure that a replacement is needed and prepare for the replacement.
Step 2 will help you select the correct replacement part.
O que você precisa
10 outras pessoas executaram este guia.
34Comentários do guia
Where can i get replacement wheels
i have a samsonite luggage w 4 wheels can i change the wheels for 4 sets or 2 wheels each for easier rolling
Too limited in the range covered. Does not mention 6"x1/2" wheel replacement.
Super tuto pas à pas pour changer sa roulette ! Ce n'est pas compliqué de réparer une valise et tous les fabricants ou importateurs le savent bien. Le plus dur est de trouver les bonnes pièces... Mais nous sommes là :) https://jereparemonbagage.com
Too bad no mention of where to find the wheels. Amazon.com does not show the wheels I need and Samsonite webpage is NO help at all.
