Ir para o conteúdo principal
Samsonite Luggage Wheel Replacement
O que você precisa
  1. Samsonite Luggage Wheel Replacement, Wheel: passo 1, imagem 1 %32
    • Clean the wheel to make sure that the wheel is not stuck.
    • Sometimes wheels don't work because they're caked with dirt or debris. This step can help you make sure that it needs to be replaced.
  2. Samsonite Luggage Wheel Replacement: passo 2, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 2, imagem 2 %32
    • Select the right replacement by measuring the diameter and width of the wheel.
  3. Samsonite Luggage Wheel Replacement: passo 3, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 3, imagem 2 %32 Samsonite Luggage Wheel Replacement: passo 3, imagem 3 %32
    • Remove the screws securing the wheel clip inside the case.
  4. Samsonite Luggage Wheel Replacement: passo 4, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 4, imagem 2 %32
    • Pull out the clip securing the wheel to the case.
  5. Samsonite Luggage Wheel Replacement: passo 5, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 5, imagem 2 %32
    • Remove the old wheel from the outside of the case.
  6. Samsonite Luggage Wheel Replacement: passo 6, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 6, imagem 2 %32
    • Insert the new wheel onto the luggage, making sure that the tubes on the wheel base align with the holes in the luggage.
  7. Samsonite Luggage Wheel Replacement: passo 7, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 7, imagem 2 %32
    • Put the clip back to its original position inside the case.
  8. Samsonite Luggage Wheel Replacement: passo 8, imagem 1 %32 Samsonite Luggage Wheel Replacement: passo 8, imagem 2 %32 Samsonite Luggage Wheel Replacement: passo 8, imagem 3 %32
    • Tighten the screws that hold the clip back in place.
Linha de Chegada
10 outras pessoas executaram este guia.
Xinyi Min
Membro desde: 01/15/21
452 Reputação
Autoria de 1 guia
34Comentários do guia
Where can i get replacement wheels
ROBERT HAGGERTY - Responder
i have a samsonite luggage w 4 wheels can i change the wheels for 4 sets or 2 wheels each for easier rolling
ondinelewitinn -
Too limited in the range covered. Does not mention 6"x1/2" wheel replacement.
Angus - Responder
Super tuto pas à pas pour changer sa roulette ! Ce n'est pas compliqué de réparer une valise et tous les fabricants ou importateurs le savent bien. Le plus dur est de trouver les bonnes pièces... Mais nous sommes là :) https://jereparemonbagage.com
reprise - Responder
Too bad no mention of where to find the wheels. Amazon.com does not show the wheels I need and Samsonite webpage is NO help at all.
Dale - Responder
Comentar
Visualizações:
Últimas 24 horas: 113
Últimos 7 dias: 1,010
Últimos 30 dias: 4,233
Ao todo: 354,106
