Introdução
This is a guide on how to disassemble the Salter Brecknell Model 311 digital scale. It identifies the steps you will need to field strip and inspect the scale.
O que você precisa
Flip the scale over, remove batteries.
It requires 4 AA batteries and has two plastic clips to hold the upper batteries.
Remove screws at 1 o'clock and 7 o'clock positions, using the mini screwdriver.
Remove screws at 5 o'clock and 11 o'clock positions, using the mini screwdriver.
Remove the weighing platform by unscrewing carefully.
Rotate it about 60 degrees so that it can be lifted vertically.
Gently tap the side of the upper plastic half, be careful as it can be snapped easily.
There are two clips that attach the upper half to the bottom half.
Lift the top half of the plastic shell to the side. Be careful, as the electrical circuit board will connect both parts.
Check for wiring issues connecting to components; look for torn cables.
Check back and front of circuit board for liquid damage.
Sometimes you can see damage from the back, but if you inspect the front side, it should be very obvious.
If you find liquid damage, unscrew the mini screws, and replace the board.
