Ir para o conteúdo principal
Safety Precautions
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
  1. Safety Precautions, Disconnect the spark plug wire: passo 1, imagem 1 %32 Safety Precautions, Disconnect the spark plug wire: passo 1, imagem 2 %32
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Safety Precautions, Flip the engine switch to the off position: passo 2, imagem 1 %32 Safety Precautions, Flip the engine switch to the off position: passo 2, imagem 2 %32
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Safety Precautions, Close the fuel valve: passo 3, imagem 1 %32 Safety Precautions, Close the fuel valve: passo 3, imagem 2 %32
    • Flip the fuel valve lever to the OFF position.
  4. Safety Precautions, Turn off the ignition: passo 4, imagem 1 %32 Safety Precautions, Turn off the ignition: passo 4, imagem 2 %32
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Safety Precautions, Allow the wheels to freewheel: passo 5, imagem 1 %32 Safety Precautions, Allow the wheels to freewheel: passo 5, imagem 2 %32 Safety Precautions, Allow the wheels to freewheel: passo 5, imagem 3 %32
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Safety Precautions, Add wheel chocks: passo 6, imagem 1 %32
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
Conclusão
Carsten Frauenheim
Membro desde: 03/10/20
156.447 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.828 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 25
