Ir para o conteúdo principal
Safely remove PC case stickers
O que você precisa
  1. Safely remove PC case stickers, Remove the battery (Laptops only): passo 1, imagem 1 %32 Safely remove PC case stickers, Remove the battery (Laptops only): passo 1, imagem 2 %32
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. Safely remove PC case stickers, Warm up the adhesive: passo 2, imagem 1 %32 Safely remove PC case stickers, Warm up the adhesive: passo 2, imagem 2 %32 Safely remove PC case stickers, Warm up the adhesive: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    iFixit Opening Picks (Set of 6)
    Comprar
    • 30-60 seconds of heat is sufficient.
    • If the sticker is thin, a guitar pick may help.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. Safely remove PC case stickers, Clean the remaining glue: passo 3, imagem 1 %32 Safely remove PC case stickers, Clean the remaining glue: passo 3, imagem 2 %32 Safely remove PC case stickers, Clean the remaining glue: passo 3, imagem 3 %32
    • While denatured alchol works, it may "strip" some rubber coatings and paint! Use good judgement!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
Linha de Chegada
6 outras pessoas executaram este guia.
Nick
Membro desde: 11/10/09
88.752 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.521 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 33
Últimos 30 dias: 129
Duração total: 15,660
