Introdução
To repair internal components of the Saeco XSmall, the top cover must be removed. It is a large molded plastic piece which includes the top and the front. This guide will show you how to remove this.
O que você precisa
Remove the lid of the bean container and remove all coffee beans.
Remove the three Torx T10 screws securing the bean container.
The finger guard made of black plastic for the grinder is attached with a Phillips screw. Remove it to remove the finger guard.
Pull the bean container vertically up and remove it.
The top cover is now only held by detents. At the front side of bottom are two tabs that go into the bottom plate, which you have to consider when removing it.
Pay attention to the steam pipe.
Start at the back seam with opening. Gently pry with a plastic opening tool to split it.
When the detents are released, carefully lift the cover upwards with your hand and tilt it diagonally forward. Watch for the tabs that are in the bottom plate.
The steam pipe is still in the front cover. You must push the cover over the steam pipe when lifting it.
12 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
