Ir para o conteúdo principal
Saab 9-3 Ignition Switch Module (ISM) Replacement
O que você precisa
  1. Saab 9-3 Ignition Switch Module (ISM) Replacement, The starting point: passo 1, imagem 1 %32
    • Our starting point: The center console with the ignition switch in the middle
    If this is bad does the clocking ignition switch have to be replace with it as well. My 2003 SAAB is not starting and the lights and gauges stopped working and were flashing. It also would not shift..Is this really caused from the ISM?
    Shondel Begley - Responder
  2. Saab 9-3 Ignition Switch Module (ISM) Replacement, The tool: passo 2, imagem 1 %32
    • This is the screwdriver bit used to remove all the screws.
  3. Saab 9-3 Ignition Switch Module (ISM) Replacement, The ISM (Ignition Switch Module): passo 3, imagem 1 %32
    • This is the item we need to replace
  4. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panels: passo 4, imagem 1 %32
    • Step one is to remove the front side panels. There is a single (covered) screw in the footwell on each side that can be removed, and the panel slides rearwards, down and out.
  5. Saab 9-3 Ignition Switch Module (ISM) Replacement, Panel screw: passo 5, imagem 1 %32
    • Unscrew and remove this screw
  6. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panel comes off: passo 6, imagem 1 %32
    • The panel can now come off.
  7. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear cover: passo 7, imagem 1 %32
    • Rear cover is removed next.
  8. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove rear panel: passo 8, imagem 1 %32
    • Next, locate the rear cover visible from the back seats, between the two front seats. Pull it sharply to the rear, and remove.
  9. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear side panels: passo 9, imagem 1 %32
    • The rear side panels in front of the rear cover are now easily accessible and can be removed.
  10. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rubber mat in front of gear lever: passo 10, imagem 1 %32
    • Next, remove the rubber mat in front of the gear lever.
  11. Saab 9-3 Ignition Switch Module (ISM) Replacement, Gear lever surround trim: passo 11, imagem 1 %32
    • The (shiny) gear lever surround trim can now be prized off, starting at the rear, and removed.
  12. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining frame holding screw: passo 12, imagem 1 %32
    • Removing the gear lever surround trim exposes a single screw holding a retaining frame underneath the gear change mechanism.
  13. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 13, imagem 1 %32
    • Unscrew the retaining screw
  14. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 14, imagem 1 %32
    • Remove the retaining frame
  15. Saab 9-3 Ignition Switch Module (ISM) Replacement, Hand brake cover: passo 15, imagem 1 %32
    • Slide out horizontally the protective plastic cover underneath the hand brake.
  16. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 16, imagem 1 %32
    • This exposes a single screw. Remove this.
    OMG, is that what this is? That is a pretty useless invention… Mine (2008, manual) doesn’t have the slit.
    Gábor Bánóczi - Responder
  17. Saab 9-3 Ignition Switch Module (ISM) Replacement, CD holder: passo 17, imagem 1 %32
    • On the other side, remove the CD holder top cover,
  18. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 18, imagem 1 %32
    • unscrew the two screws inside,
  19. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 19, imagem 1 %32
    • and remove the CD holder itself. This exposes another single screw. Remove this.
  20. Saab 9-3 Ignition Switch Module (ISM) Replacement, Storage unit: passo 20, imagem 1 %32
    • Remove the bottom rubber cover in the centre console storage unit.
  21. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 21, imagem 1 %32
    • This exposes two screws that need removing.
  22. Saab 9-3 Ignition Switch Module (ISM) Replacement, Drinks holder: passo 22, imagem 1 %32
    • The drinks holder has another rubber mat.
  23. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 23, imagem 1 %32
    • There are no screws underneath, but this is a good opportunity to remove it and clean it separately.
  24. Saab 9-3 Ignition Switch Module (ISM) Replacement, Air duct: passo 24, imagem 1 %32
    • Underneath the air vent controlling air flow to the passengers from the center console sits a square duct.
  25. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 25, imagem 1 %32
    • The Haynes manual suggests pulling this out next, and although it is possible to do so, it requires force, and is much easier to do later when all other fixings have been removed.
  26. Saab 9-3 Ignition Switch Module (ISM) Replacement, Cable bundles: passo 26, imagem 1 %32
    • There are two cable bundles connected to the center console from the rest of the car. One is connected via a large, square plug with a red tab.
  27. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 27, imagem 1 %32
    • Push a screwdriver inside the red tab and pull, and the connector splits neatly apart.
    Would you happen to know which of those wires sends the voltage when cranked? I know the violet/yellow one provides voltage when key is turned to ‘on’. I’m trying to install a push button starts. Thanks!
    Tito Sanchez - Responder
  28. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 28, imagem 1 %32
    • The other is an earth connector near the rear of the console. This can easily be pulled away.
  29. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining screws in front of the gear lever: passo 29, imagem 1 %32
    • Remove two screws located in front of the gear lever.
  30. Saab 9-3 Ignition Switch Module (ISM) Replacement, Horizontal retainer screws -- a fiddle to get out!!: passo 30, imagem 1 %32
    • The next bit is a bit fiddly to get to: There are two screws going horizontally, one underneath the handbrake,
  31. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 31, imagem 1 %32
    • the other on the CD holder side. These need to be removed. There is limited workspace. Use a separate loose screwdriver bit, and a spanner to twist it.
  32. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: passo 32, imagem 1 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: passo 32, imagem 2 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: passo 32, imagem 3 %32
    • The center console is now loose, and can be puller backwards and upwards, and removed from the car.
  33. Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: passo 33, imagem 1 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: passo 33, imagem 2 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: passo 33, imagem 3 %32
    • Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket.
  34. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 34, imagem 1 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 34, imagem 2 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 34, imagem 3 %32
    • The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector.
  35. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 35, imagem 1 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 35, imagem 2 %32
    • You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again.
    Did you go for a genuine ISM? How is it holding up today?
    Machachi - Responder
    • The rest of the procedure is doing the dismantling in reverse. However, this is the best order that I found (choosing the wrong order once or twice):
  36. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 37, imagem 1 %32
    • The square air conditioning duct goes in first. The console goes in next. It is a bit awkward to riggle past all the lugs, screws, tabs and cables, but just persevere. Once in, fit all the screws holding it in place, including the awkward ones.
  37. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 38, imagem 1 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 38, imagem 2 %32 Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 38, imagem 3 %32
    • Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed.
    This is a good time to test out your new switch if you haven’t already.
    Andy Hudson - Responder
    • Next, fit the retaining frame underneath the gear lever, all screws around it, then the shiny gear lever surround trim, and finally the rubber mat in front of it. Fit the side rear panels, then the front panels (fasten them with the single screw), then the rear cover.
  38. Saab 9-3 Ignition Switch Module (ISM) Replacement: passo 40, imagem 1 %32
    • With all side panels in place, re-fit the screws around the gear lever and CD holder. Finally, slide the handbrake cover in place, and screw the CD holder in. All rubber mats put in place (you *did* clean them whilst you had the chance, right..?). You are done!
    • Touch Wood, my car is now purring, with none of the issues I had before. Having heard quotes from around £1,000 upwards for a complete ISM / CIM refit, I am well pleased with the result.
    I have not as yet got the replacement part but, I'm not saying that it'll be the easiest set of instructions to follow. It looks like it's not going to be the hardest either, thank you.
    waynesthe1 - Responder
    Just completed fitting ism … driving the car for a couple of days to make sure issues resolved before putting the rest of Humpty Dumpty back together again
    thanks very much for posting this, was quite satisfying to do, saved a fortune
    Cheers
    David
    david ward - Responder
    Did you have any issues with Key not Recognized message ?? I’m having it but both keys previously worked
    Brian E Gorrell - Responder
Conclusão
15 outras pessoas executaram este guia.
Lars Erlandsen
Membro desde: 04/17/18
1.313 Reputação
Autoria de 2 guias
26 comentários
And the key worked once plugged in and the battery is reconnected?
Michael Sullivan - Responder
These are great instructions. I had the dreaded ‘steering lock malfunction’ warning message on my 9-3. Bought an ISM off eBay for £35 and had it fitted and working fine in 2 hours. Thanks so much for posting.
Mike - Responder
Instructuctions spot on. In 1.5hrs I had the ISM out, cleaned and back in. And no more steering lock errors. !!!
gtsmail951 - Responder
Does anyone have advice on how to replace the ignition switch on a 1998 9.3 automatic transmission Saab
davina gammon - Responder
Most of these steps are not necessary at all, you can pull the ISM out from the side when you have removed the side panel, its tight but more than possible. This is very easy, 3h is a joke it takes 30 minutes at most!
Filip Andersson - Responder
My starting point was a Haynes manual. Not all the steps worked as described. The steps above will work. Three hours it took, and it didn’t feel like a joke. By the way, the Saab is still chugging along nicely (touch wood). Not missed a beat since the repair.
Glad you’ve found an easier way. For the rest of the mere mortals, me included, the above steps will work.
Lars Erlandsen -
Any clue as to why after install of new switch the key won't turn?
Ryan Nordbrock -
Does it need coding into car or is it just plug and go
Jason platten - Responder
The steering wheel unit will need re-programming. However, the ignition switch that I replaced, listed above, needs no re-programming at all!
Lars Erlandsen -
Great instructions. I also had the ‘steering lock malfunction’ warning message on my 2011 soft top 9-3. Fixed by replacing the ISM with a used item from eBay for £38. If only Haynes instructions were this good!
David Saker - Responder
Très bon tutoriel changement en 1H30 .
Merci beaucoup Lars
didier.vanelslande - Responder
vous êtes les bienvenus (Google translation from “you are welcome”) :-)
Lars Erlandsen -
Thanks for this advice - it’s really well produced. However I can also vouch for the alternative method which just involves removing the side panels and carefully lowering the ISM out of the left hand side. In total the job took about 20-30 mins and the car is good as new now. I also removed the gear lever surround to give it a good clean. But still thank you as I did follow a few of your steps.
Jeff Hilton - Responder
Thanks great photos and information is ism plug and play or needs re programming thanks Clive
Clive Briggs - Responder
Hi, Clive.
The ignition switch in the center console is plug and play. The unit that is wrapped around the steering wheel, however, needs re-programming. I was warned this would involve a 4 figure sum of money, so I was happy my £120 key switch gamble replacement did the trick. And the Saab is still running. With the key switch working flawlessly…
Lars Erlandsen -
Thanks for the tips. I solved the same problem at the service station. But I installed the timing light for MSD ignition myself using your instructions.
William Clark - Responder
Do i need to code/program it after replacement? What about keys, do they need to be coded again?
Robert Rupa - Responder
Just read your instructions and followed them to the letter , many thanks
Julian Barnes - Responder
Hello, do you know if a Tech2 reprogrammation is needed once ISM has been changed? Is it part of security components of the car?
Famille Ponal - Responder
and is OBD fault “B3057 ox48” linked to ISM module issue?
Hi.
As I said in my tutorial, replacing the key module does not require any re-programming. If you replace the full security module around the steering wheel, it will need all re-programming…
Thanks,
Lars Erlandsen.
Lars Erlandsen - Responder
The NIST frameworks were designed as flexible, voluntary frameworks. The fact that they are flexible makes it relatively easy to implement them in conjunction with ISO 27001.
This is largely due to both standards having a number of common principles, including; requiring senior management support, a continual improvement process, and a risk-based approach.
6 Clicks
Dillon Mitchell - Responder
6 Clicks
I have a question. What issues were you having that made you replace it. I’m getting the steering wheel lock message and sometimes the car won’t start. I have to take the key out and put it back in and try again to start it. Also I don’t hear the steering wheel unit unlocking everytime like it used too. It says steering wheel locked but it’s not actually physically locked. I’m hoping it just needs a new ism.
Twinturbobmw 535xi - Responder
For reference, this is exactly the scenario that I faced, and that made me replace the unit in the first place (and write the tutorial).
Lars Erlandsen -
I cant turn the key in my ignotion [2006 9-3 auto wagon runs sweet as a bell] . when I put the key in the ignotion the needles on the instrument panel dance/vibrate? ! Its liek the key has forgotten it belongs to the car Again. [this happened a few weeks ago, but it was with my mechanic and he simply re-programmed the key]. Do I need to go throiugh the busdiness of changing the ISM?
firefly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 38
Últimos 30 dias: 260
Duração total: 32,494
