Ir para o conteúdo principal
SVP 5800 Front Casing Replacement
O que você precisa
  1. SVP 5800 Front Casing Replacement, Strap Hook: passo 1, imagem 1 %32 SVP 5800 Front Casing Replacement, Strap Hook: passo 1, imagem 2 %32 SVP 5800 Front Casing Replacement, Strap Hook: passo 1, imagem 3 %32
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Front Casing Replacement, Front Casing: passo 2, imagem 1 %32 SVP 5800 Front Casing Replacement, Front Casing: passo 2, imagem 2 %32
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Front Casing Replacement: passo 3, imagem 1 %32 SVP 5800 Front Casing Replacement: passo 3, imagem 2 %32
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Front Casing Replacement: passo 4, imagem 1 %32 SVP 5800 Front Casing Replacement: passo 4, imagem 2 %32
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
Conclusão
Uma outra pessoa concluiu este guia.
Cheyenne Heinen
Membro desde: 03/07/16
358 Reputação
Autoria de 3 guias
Equipe
Marist, Team 1-3, Laflen Spring 2016 Membro de Marist, Team 1-3, Laflen Spring 2016
MARS-LAFLEN-S16S1G3
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 305
