Ir para o conteúdo principal
SRS-XB22 Battery Replacement
O que você precisa
  1. SRS-XB22 Battery Replacement, Remove the front grill: passo 1, imagem 1 %32 SRS-XB22 Battery Replacement, Remove the front grill: passo 1, imagem 2 %32 SRS-XB22 Battery Replacement, Remove the front grill: passo 1, imagem 3 %32
    • Firstly, you need to pry the speaker grill away from the speaker.
    • Use a spudger/guitar pick to prise up each end of the grill.
    • You are trying to lift a clip at either end. (circled in red)
    • Once lifted at both ends, gently pull the grill forwards.
  2. SRS-XB22 Battery Replacement, Unscrew the speakers: passo 2, imagem 1 %32 SRS-XB22 Battery Replacement, Unscrew the speakers: passo 2, imagem 2 %32 SRS-XB22 Battery Replacement, Unscrew the speakers: passo 2, imagem 3 %32
    • Completely remove the grill.
    • Remove the 8 screws that hold the speakers in place.
    • Slowly pull the speakers forward to free them from the case.
  3. SRS-XB22 Battery Replacement, Remove the speakers: passo 3, imagem 1 %32 SRS-XB22 Battery Replacement, Remove the speakers: passo 3, imagem 2 %32 SRS-XB22 Battery Replacement, Remove the speakers: passo 3, imagem 3 %32
    • Disconnect the speaker cables from the internal circuit boards.
    • Be careful, the sockets are easy to damage
    • Remove both of the rubber gaskets from the case - one for the left speaker, one for the right.
  4. SRS-XB22 Battery Replacement, Removing the outer case.: passo 4, imagem 1 %32 SRS-XB22 Battery Replacement, Removing the outer case.: passo 4, imagem 2 %32 SRS-XB22 Battery Replacement, Removing the outer case.: passo 4, imagem 3 %32
    • Starting at the ends of the speaker, prise the back case away from the main unit.
    • Work your way along the front of the case.
    • Once the front in freed, work you way along the edges, freeing the whole case.
    • There is A LOT of double sided tape between the outer and inner case. It requires a lot of work to remove it.
    • The case is one piece. Although it looks as if it splits at the rear, it is sealed together.
  5. SRS-XB22 Battery Replacement, Remove the rear casing: passo 5, imagem 1 %32 SRS-XB22 Battery Replacement, Remove the rear casing: passo 5, imagem 2 %32
    • Remove the rear outer casing of the speaker.
  6. SRS-XB22 Battery Replacement, Remove the front cover: passo 6, imagem 1 %32 SRS-XB22 Battery Replacement, Remove the front cover: passo 6, imagem 2 %32 SRS-XB22 Battery Replacement, Remove the front cover: passo 6, imagem 3 %32
    • Remove 3 screws at either end of the speaker, so 6 screws in total.
    • Using a spudger, unclip the top and bottom plastic clips, holding the front of the speaker.
    • (I made the error and removed the illuminated surround, hence it is not in two of my pictures here - it is NOT necessary to remove it)
  7. SRS-XB22 Battery Replacement, Disconnect the front panel: passo 7, imagem 1 %32 SRS-XB22 Battery Replacement, Disconnect the front panel: passo 7, imagem 2 %32
    • Slowly pull the front panel forwards.
    • Be careful, there are 3 wires still connected.
    • Disconnect the three wires, freeing the front panel.
  8. SRS-XB22 Battery Replacement, Freeing the internal components: passo 8, imagem 1 %32 SRS-XB22 Battery Replacement, Freeing the internal components: passo 8, imagem 2 %32 SRS-XB22 Battery Replacement, Freeing the internal components: passo 8, imagem 3 %32
    • Lift the rubber gasket away from the unit.
    • Locate the 6 screws holding the internal structure in place.
    • Remove these 6 screws.
  9. SRS-XB22 Battery Replacement: passo 9, imagem 1 %32 SRS-XB22 Battery Replacement: passo 9, imagem 2 %32 SRS-XB22 Battery Replacement: passo 9, imagem 3 %32
    • Use a spudger to lift the button away from the speaker.
    • Be careful, it's held down by more sticky tape!
  10. SRS-XB22 Battery Replacement, Remove the internal structure: passo 10, imagem 1 %32
    • Slide the main plastic unit forward from the speaker.
    • There will still be a couple of circuit boards in the back that are connected. These are the boards for the rear panel.
  11. SRS-XB22 Battery Replacement, Remove the battery: passo 11, imagem 1 %32 SRS-XB22 Battery Replacement, Remove the battery: passo 11, imagem 2 %32 SRS-XB22 Battery Replacement, Remove the battery: passo 11, imagem 3 %32
    • Disconnect the battery lead from the circuit board.
    • Carefully, pull the battery out of its recess.
Conclusão
7 outras pessoas executaram este guia.
Charlie Turner
Membro desde: 05/22/20
423 Reputação
Autoria de 1 guia
4 comentários
has anyone ever heard the battery lady come on by herself? could it be cause I knocked it a bit too hard accidentally while attached to backpack? I loosened something inside on board?
Jeff Sparky - Responder
So the battery type is st-05s, thank you.
Karlis Liepa - Responder
Battery order plz
Somi Rai - Responder
you can find it on amazon. this is the one im trying out tomorrow.
https://www.amazon.com/gp/product/B0BC7W...
Danah AlAwadhi -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 40
Últimos 30 dias: 191
Duração total: 6,754
