Ir para o conteúdo principal
SR405QM Battery Replacement
O que você precisa
  1. SR405QM Battery Replacement, Battery: passo 1, imagem 1 %32
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: passo 3, imagem 1 %32 SR405QM Battery Replacement: passo 3, imagem 2 %32
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: passo 4, imagem 1 %32 SR405QM Battery Replacement: passo 4, imagem 2 %32 SR405QM Battery Replacement: passo 4, imagem 3 %32
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Conclusão
To reassemble your device, follow these instructions in reverse order with a fresh battery.
Chris Pittner
Membro desde: 01/11/13
220 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-18, Forte Winter 2013 Membro de Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,178
