Ir para o conteúdo principal
SR 306-12951100 Acoustic Guitar Tuning Keys Replacement
O que você precisa
  1. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: passo 1, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: passo 1, imagem 2 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: passo 1, imagem 3 %32
    • Remove the four outer screws.
    • Then remove the four inner screws.
    • The screws are located on the back of the guitar head.
  2. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 2, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 2, imagem 2 %32
    • Slide all of the collars off of the old tuning keys.
    • The collars are found on the tuning key pegs on the front head of the guitar. One of the collars is indicated in the first picture.
    • Some of the collars may be difficult to remove. Apply gentle pressure until they pop off.
  3. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 3, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 3, imagem 2 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 3, imagem 3 %32
    • Remove the old tuning keys by sliding them out of the holes.
    • It helps to put the guitar on its side and hold the head of the guitar from the front and push the old tuning keys out the back.
  4. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 4, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 4, imagem 2 %32
    • Clean the guitar head and tuning key holes using a microfiber cloth to ensure that the new tuning keys will fit properly.
    • This step may require more or less effort depending on how much epoxy was used to hold the old tuning keys in place.
  5. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 5, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 5, imagem 2 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 5, imagem 3 %32
    • Insert one of the new tuning key racks into the appropriate tuning key holes.
    • Both of the new tuning key pieces are identical, so either plate can be used.
    • The plate should have an overall length of 102 mm. The center to center distance between posts should be 35 mm.
  6. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 6, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 6, imagem 2 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 6, imagem 3 %32
    • Insert the second tuning key rack into the appropriate tuning key holes.
  7. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 7, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 7, imagem 2 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 7, imagem 3 %32
    • Begin installing the four outer screws.
    • Then install the four inner screws.
    • The dimensions of the screws that come with the kit are 31 mm x 35 mm x 27 mm.
    • Do not tighten the screws until all of them are in place. Once all eight screws are in, go back and tighten each one. This is done so that the new tuning keys can be properly aligned.
  8. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 8, imagem 1 %32 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: passo 8, imagem 2 %32
    • The tuning keys are now properly installed.
    • Install new guitar strings by following this video (start at 1 min 20 sec.) and this guide.
Linha de Chegada
2Comentários do guia
I literally just bought this exact guitar at goodwill!
Hugh Bourns - Responder
Hi Michael,
I just bought this exact guitar at an estate sale this past weekend I bought it for my granddaughter to learn how to play the neck has a little bow in it and I was wondering if you knew what size the adjustment screw is and what type head it is.
Thanks!
Dennis
D Carter - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 789
