Introdução
If SPOT X SPOTXB's USB-port is broken, this will affect the device's charging ability and any data transfer activities. So, it is important that the USB-port for this device is able to work anytime, any day. To replace the broken USB Port, it might require de-assembling the device.
O que você precisa
Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
Uma outra pessoa concluiu este guia.
