Introdução
If your SPOT X SPOT XB Satellite Messenger isn't charging correctly or not turning on, you can replace its battery to maintain proper operation and extend the life of the device. This guide will walk you through a few simple steps to safely remove your old battery and install a new one.
O que você precisa
Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
Desolder the battery cables from the motherboard.
Remove the battery from the device.
Uma outra pessoa concluiu este guia.
