Ir para o conteúdo principal
SPC GEAR GK630 Keyboard Switch Replacement
O que você precisa
    • Unplug cable from keyboard and remove all key caps.
    • Unscrew all screws (there are no screws on the bottom of the keyboard), there should be 13 screws.
    • After removing all the screws turn the keyboard upside down and the upper part should fell off, but hold it they are sill connected with black cable, unplug that cable.
    • Using soldering iron touch its tip to the pin and when it melts press pump on it and push the button. Th pump should suck all the melted solder, if it failed try again
Conclusão
To reassemble your device, follow these instructions in reverse order of course except soldering part.
favzed
Membro desde: 07/12/24
109 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 58
Ao todo: 929
