Introdução
Subwoofers are notorious for blowing out. Consistent use at low frequencies result in a short life span for these parts.
This guide will show you how to replace the subwoofer instead of having to throw out you entire device. A replacement subwoofer can be found online or salvaged from another device.
O que você precisa
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
Begin with the front component after the disassembly prerequisite.
This guide is for the subwoofer seen in the middle of this image.
Uma outra pessoa concluiu este guia.
