Ir para o conteúdo principal
SONY ZS-BTG900 Remote Motherboard Replacement
O que você precisa
  1. SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: passo 1, imagem 1 %32 SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: passo 1, imagem 2 %32
    • Flip the remote and remove the backing.
  2. SONY ZS-BTG900 Remote Motherboard Replacement: passo 2, imagem 1 %32 SONY ZS-BTG900 Remote Motherboard Replacement: passo 2, imagem 2 %32
    • Locate the screw behind the battery pack.
    • Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
  3. SONY ZS-BTG900 Remote Motherboard Replacement: passo 3, imagem 1 %32 SONY ZS-BTG900 Remote Motherboard Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
    • Do this until the top half of the remote comes loose.
  4. SONY ZS-BTG900 Remote Motherboard Replacement: passo 4, imagem 1 %32 SONY ZS-BTG900 Remote Motherboard Replacement: passo 4, imagem 2 %32
    • Carefully remove the top to reveal the button covers and the remote control board.
  5. SONY ZS-BTG900 Remote Motherboard Replacement: passo 5, imagem 1 %32 SONY ZS-BTG900 Remote Motherboard Replacement: passo 5, imagem 2 %32
    • Lift the chip out of the plastic casing to replace it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 435
