Introdução
This guide is going to show you how to open and disassemble the Sony ZS-BTG 900. By the end of the guide you will have three main areas of the device standing the alone. The three areas will be: the top, the base, and the front.
O que você precisa
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
1Comentário do guia
Alfredo and any others who developed this guide - you are awesome! Thank you very much for the great level of detail. Saved me a bunch of time.
