Ir para o conteúdo principal
SONY Alpha NEX-3N Flash Assembly Replacement
O que você precisa
  1. SONY Alpha NEX-3N Flash Assembly Replacement, Getting Started: passo 1, imagem 1 %32 SONY Alpha NEX-3N Flash Assembly Replacement, Getting Started: passo 1, imagem 2 %32
    • Remove battery and card
  2. SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 1: passo 2, imagem 1 %32 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 1: passo 2, imagem 2 %32 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 1: passo 2, imagem 3 %32
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 2: passo 3, imagem 1 %32
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 3: passo 4, imagem 1 %32 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 3: passo 4, imagem 2 %32 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 3: passo 4, imagem 3 %32
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. SONY Alpha NEX-3N Flash Assembly Replacement, LCD assembly: passo 5, imagem 1 %32 SONY Alpha NEX-3N Flash Assembly Replacement, LCD assembly: passo 5, imagem 2 %32
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. SONY Alpha NEX-3N Flash Assembly Replacement, LCD Assembly: passo 6, imagem 1 %32 SONY Alpha NEX-3N Flash Assembly Replacement, LCD Assembly: passo 6, imagem 2 %32 SONY Alpha NEX-3N Flash Assembly Replacement, LCD Assembly: passo 6, imagem 3 %32
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. SONY Alpha NEX-3N Flash Assembly Replacement, The LCD assembly: passo 7, imagem 1 %32
    • The LCD assembly
  8. SONY Alpha NEX-3N Flash Assembly Replacement, Screws: passo 8, imagem 1 %32
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  9. SONY Alpha NEX-3N Flash Assembly Replacement: passo 9, imagem 1 %32 SONY Alpha NEX-3N Flash Assembly Replacement: passo 9, imagem 2 %32
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  10. SONY Alpha NEX-3N Flash Assembly Replacement: passo 10, imagem 1 %32
    • Remove that part whatever called, by sliding it backwards.
Conclusão
Uma outra pessoa concluiu este guia.
Terrance
Membro desde: 11/17/09
6.359 Reputação
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 19
Duração total: 177
