Ir para o conteúdo principal
SM Santa Marin hand watch Battery Replacement
O que você precisa
  1. SM Santa Marin hand watch Battery Replacement, Battery: passo 1, imagem 1 %32
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: passo 2, imagem 1 %32
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: passo 3, imagem 1 %32
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: passo 4, imagem 1 %32
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: passo 5, imagem 1 %32
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: passo 6, imagem 1 %32 SM Santa Marin hand watch Battery Replacement: passo 6, imagem 2 %32
    • Take the old battery out using the plastic opening tool or spudger.
Conclusão
Aziz Zabarmawi
Membro desde: 10/07/19
133 Reputação
Autoria de 1 guia
Um comentário
It's amazing and also work as a machenic for me
Talha - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 23
Duração total: 994
