Ir para o conteúdo principal
SKYTEX SP1020 Battery Replacement
O que você precisa
  1. SKYTEX SP1020 Battery Replacement, Rear Case: passo 1, imagem 1 %32 SKYTEX SP1020 Battery Replacement, Rear Case: passo 1, imagem 2 %32
    • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
    • Turn off device prior to continuing to further steps.
  2. SKYTEX SP1020 Battery Replacement: passo 2, imagem 1 %32 SKYTEX SP1020 Battery Replacement: passo 2, imagem 2 %32 SKYTEX SP1020 Battery Replacement: passo 2, imagem 3 %32
    • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
    • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
    • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
  3. SKYTEX SP1020 Battery Replacement: passo 3, imagem 1 %32
    • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
  4. SKYTEX SP1020 Battery Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry the speakers out of the rear case.
    • The rear case will now be free from the rest of the device.
  5. SKYTEX SP1020 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Locate the battery.
  6. SKYTEX SP1020 Battery Replacement: passo 6, imagem 1 %32
    • Use a soldering iron and desoldering braid to desolder the red and black motherboard battery connections.
  7. SKYTEX SP1020 Battery Replacement: passo 7, imagem 1 %32
    • Gently lift the battery up and out of the device.
Conclusão
Anthony Vitali
Membro desde: 03/23/15
293 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-6, Miles Spring 2015 Membro de UMass Dartmouth, Team 1-6, Miles Spring 2015
UMASSD-MILES-S15S1G6
Membros da 4
Autoria de 8 guias
Um comentário
Great Instructions! where did you get the battery for the Skytex ?
joe_capozzi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 745
