Ir para o conteúdo principal
SHARP EL-W53XG WriteView Battery Replacement
O que você precisa
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: passo 1, imagem 1 %32 SHARP EL-W53XG WriteView  Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: passo 2, imagem 1 %32
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: passo 3, imagem 1 %32 SHARP EL-W53XG WriteView  Battery Replacement: passo 3, imagem 2 %32
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: passo 4, imagem 1 %32 SHARP EL-W53XG WriteView  Battery Replacement: passo 4, imagem 2 %32
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: passo 5, imagem 1 %32
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: passo 6, imagem 1 %32
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
Conclusão
Faduma Hagi
Membro desde: 09/14/21
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 46
Duração total: 1,231
