Ir para o conteúdo principal
SHARP EL-546XT Battery Replacement
O que você precisa
  1. SHARP EL-546XT Battery Replacement, Battery: passo 1, imagem 1 %32 SHARP EL-546XT Battery Replacement, Battery: passo 1, imagem 2 %32
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: passo 2, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 2, imagem 2 %32 SHARP EL-546XT Battery Replacement: passo 2, imagem 3 %32
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: passo 3, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 3, imagem 2 %32 SHARP EL-546XT Battery Replacement: passo 3, imagem 3 %32
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: passo 4, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 4, imagem 2 %32
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: passo 5, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 5, imagem 2 %32 SHARP EL-546XT Battery Replacement: passo 5, imagem 3 %32
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: passo 6, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 6, imagem 2 %32 SHARP EL-546XT Battery Replacement: passo 6, imagem 3 %32
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: passo 7, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 7, imagem 2 %32
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: passo 8, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 8, imagem 2 %32 SHARP EL-546XT Battery Replacement: passo 8, imagem 3 %32
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: passo 9, imagem 1 %32 SHARP EL-546XT Battery Replacement: passo 9, imagem 2 %32 SHARP EL-546XT Battery Replacement: passo 9, imagem 3 %32
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
Linha de Chegada
Mithunan Sivagnanam
Membro desde: 05/22/23
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Duração total: 330
