Ir para o conteúdo principal
SHARK WANDVAC WV205 Battery Replacement
O que você precisa
  1. SHARK WANDVAC WV205 Battery Replacement, Battery: passo 1, imagem 1 %32 SHARK WANDVAC WV205 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Push the sliding button to open the dirt capsule to empty it out.
    • Ensure to do this over a garbage can/bag to prevent a mess.
  2. SHARK WANDVAC WV205 Battery Replacement: passo 2, imagem 1 %32 SHARK WANDVAC WV205 Battery Replacement: passo 2, imagem 2 %32
    • Using a coin or other thin item, such as a guitar pick, push the cap at the end of the vacuum out. Switch between sides to make it come out evenly.
    • This could take more time than expected.
  3. SHARK WANDVAC WV205 Battery Replacement: passo 3, imagem 1 %32 SHARK WANDVAC WV205 Battery Replacement: passo 3, imagem 2 %32
    • Once the battery is popped out, carefully pull it out.
  4. SHARK WANDVAC WV205 Battery Replacement: passo 4, imagem 1 %32 SHARK WANDVAC WV205 Battery Replacement: passo 4, imagem 2 %32
    • To properly store and then dispose of the battery put it in a clear plastic bag.
  5. SHARK WANDVAC WV205 Battery Replacement: passo 5, imagem 1 %32 SHARK WANDVAC WV205 Battery Replacement: passo 5, imagem 2 %32
    • Slot your replacement battery where the old one was.
    • Once inside, push hard on the end until you hear a click.
  6. SHARK WANDVAC WV205 Battery Replacement: passo 6, imagem 1 %32
    • Test the vacuum to ensure the replacement succeeded.
Conclusão
To properly dispose of the old battery consult your cities policies on lithium ion battery disposal.
Nicolaas
Membro desde: 01/16/24
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 62
Duração total: 178
