Ir para o conteúdo principal
SGH-A117 keypad replacement
O que você precisa
  1. SGH-A117 keypad replacement, Battery: passo 1, imagem 1 %32
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
  2. SGH-A117 keypad replacement: passo 2, imagem 1 %32
    • Lift the bottom of the battery and then move it up and away.
  3. SGH-A117 keypad replacement, Motherboard: passo 3, imagem 1 %32
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
  4. SGH-A117 keypad replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
  5. SGH-A117 keypad replacement: passo 5, imagem 1 %32
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
  6. SGH-A117 keypad replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
  7. SGH-A117 keypad replacement, Keypad: passo 7, imagem 1 %32
    • After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
  8. SGH-A117 keypad replacement: passo 8, imagem 1 %32
    • Replace the faulty keypad, and reassemble the phone.
Conclusão
Stephanie Isaac
Membro desde: 09/11/15
431 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 279
