Introdução
The keypad is something that is used quite often on a phone when texting or emailing. Due to the constant use of the keypad, the keypad can possibly become worn out.
The process of replacing the keypad is a bit challenging and requires patience and attention to detail. The equipment you are working with is very delicate and if not assembled properly, it will break.
O que você precisa
Remove the battery by pressing the battery lock down and slide the battery cover away.
Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
