Introdução
This guide will help you replace the back cover of you controller. You’ll only need a Phillips #000 screwdriver to complete this guide.
  1. Remove the screws on the back of the controller with the Phillips #000 screwdriver. Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside. Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Hold the controller with the bottom plate facing up, gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    • Place screws on magnetic project mat to avoid losing any screws.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
Conclusão
2 outras pessoas concluíram este guia.
Omar Shorab
249 reputação
2 Guides authored
Equipe
Cal Poly, Team S24-G12, Maness Spring 2018 Membro de Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Todo: 92
