Ir para o conteúdo principal
SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement
O que você precisa
  1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Battery: passo 1, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Battery: passo 1, imagem 2 %32
    • Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
  2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 2, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 2, imagem 2 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 2, imagem 3 %32
    • Press the button to release the bottom cover.
  3. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 3, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 3, imagem 2 %32
    • Remove the five 4.3mm Phillips #00 screws from the battery.
  4. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 4, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 4, imagem 2 %32
    • Lift the battery with both hands and remove.
  5. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: passo 5, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: passo 5, imagem 2 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: passo 5, imagem 3 %32
    • Disconnect the display cable from the motherboard.
  6. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 6, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 6, imagem 2 %32
    • Disconnect the black and white antenna cables from the Wi-Fi card.
  7. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 7, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 7, imagem 2 %32
    • Remove the five 4mm Phillips #00 screws from the motherboard retaining brackets.
  8. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 8, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 8, imagem 2 %32
    • Remove the eight silver 4.2mm Phillips #00 screws from the corner.
  9. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 9, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 9, imagem 2 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 9, imagem 3 %32
    • Pry up the metal hinges from the laptop.
  10. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 10, imagem 1 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 10, imagem 2 %32 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: passo 10, imagem 3 %32
    • Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside.
Conclusão
Uma outra pessoa concluiu este guia.
Sean Kim
Membro desde: 04/12/18
640 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G2, Liner Spring 2018 Membro de UW Tacoma, Team S1-G2, Liner Spring 2018
UWT-LINER-S18S1G2
Membros da 5
Autoria de 4 guias
Um comentário
There’s no need to remove the battery. Just disconnect its power socket if you want to be ‘careful’.
Steerpike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 590
