Ir para o conteúdo principal
S.A. Gear MSS-1600 Pulley Replacement
O que você precisa
  1. S.A. Gear MSS-1600 Pulley Replacement, Pulley: passo 1, imagem 1 %32 S.A. Gear MSS-1600 Pulley Replacement, Pulley: passo 1, imagem 2 %32 S.A. Gear MSS-1600 Pulley Replacement, Pulley: passo 1, imagem 3 %32
    • Place your adjustable wrench on the nut, adjust it to fit, and use the Allen wrench to hold the bolt in place when removing the nut.
    • Take off the washer that is with the nut and put them both aside for later.
  2. S.A. Gear MSS-1600 Pulley Replacement: passo 2, imagem 1 %32 S.A. Gear MSS-1600 Pulley Replacement: passo 2, imagem 2 %32 S.A. Gear MSS-1600 Pulley Replacement: passo 2, imagem 3 %32
    • Use your Allen wrench and unscrew the bolt. After this the pulley will have nothing holding it.
    • Take the worn-out pulley off the machine and put it aside.
    • Take your new pulley and place it were the worn-out pulley used to be and hold it in place.
    • You may need another pair of hands to hold the pulley in place while you put the bolt back into place.
  3. S.A. Gear MSS-1600 Pulley Replacement: passo 3, imagem 1 %32 S.A. Gear MSS-1600 Pulley Replacement: passo 3, imagem 2 %32 S.A. Gear MSS-1600 Pulley Replacement: passo 3, imagem 3 %32
    • Place the washer, then the Allen bolt in the pulley and use the Allen wrench to screw it back into place.
    • Place the nut on the bolt and tighten by hand. Then use the adjustable wrench to tighten it completely.
    • Do not screw your nut on too tight. If the nut is too tight the pulley will not have a full range of motion and your equipment will seem stiff when you try and use it.
    • Once everything is set-up take your old pulley and dispose of it by taking it to the appropriate waste disposal company.
Conclusão
Make sure to test your equipment to ensure everything operates as it should.
Artis Hardaway
Membro desde: 09/29/21
97 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 323
