Ir para o conteúdo principal
Ryobi VC120 Motor Replacement
O que você precisa
  1. Ryobi VC120 Motor Replacement, Filter: passo 1, imagem 1 %32
    • Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
  2. Ryobi VC120 Motor Replacement: passo 2, imagem 1 %32 Ryobi VC120 Motor Replacement: passo 2, imagem 2 %32
    • Grab the filter with two fingers and slide it out.
  3. Ryobi VC120 Motor Replacement, Motor: passo 3, imagem 1 %32 Ryobi VC120 Motor Replacement, Motor: passo 3, imagem 2 %32
    • Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
    • There are two types of screws on this device. You may want to use a magnetic screw pad to organize your screws to be sure they return to their designated holes.
    • 4x 19.1mm
    • 1x 14.3mm
    • Once the screws are removed, you should be able to separate the side panel from the rest of the device.
  4. Ryobi VC120 Motor Replacement: passo 4, imagem 1 %32 Ryobi VC120 Motor Replacement: passo 4, imagem 2 %32 Ryobi VC120 Motor Replacement: passo 4, imagem 3 %32
    • Pull your motor out, and remove the black and red cables from the motor by hand.
Conclusão
3 outras pessoas executaram este guia.
Allison Schoch
Membro desde: 09/16/15
689 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 2-4, Baechle Fall 2015 Membro de IUPUI, Team 2-4, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 816
