Ir para o conteúdo principal
Ryobi RS290G Motor Replacement
O que você precisa
  1. Ryobi RS290G Motor Replacement, Top Cap: passo 1, imagem 1 %32
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Motor Replacement: passo 2, imagem 1 %32
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Motor Replacement: passo 3, imagem 1 %32
    • Remove the top cap.
  4. Ryobi RS290G Motor Replacement, Switch Trigger: passo 4, imagem 1 %32
    • Remove the switch trigger.
  5. Ryobi RS290G Motor Replacement, Motor: passo 5, imagem 1 %32
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Motor Replacement: passo 6, imagem 1 %32
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Motor Replacement: passo 7, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 7, imagem 2 %32
    • Slide the power switch out of the housing assembly.
  8. Ryobi RS290G Motor Replacement: passo 8, imagem 1 %32
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Motor Replacement: passo 9, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 9, imagem 2 %32
    • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
  10. Ryobi RS290G Motor Replacement: passo 10, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 10, imagem 2 %32
    • Slide out the brush assembly with the black lead from the inner housing assembly.
  11. Ryobi RS290G Motor Replacement: passo 11, imagem 1 %32
    • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
    • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
  12. Ryobi RS290G Motor Replacement: passo 12, imagem 1 %32
    • Remove the armature assembly, with the motor, out of the inner housing assembly.
  13. Ryobi RS290G Motor Replacement: passo 13, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 13, imagem 2 %32 Ryobi RS290G Motor Replacement: passo 13, imagem 3 %32
    • Replace the motor (also known as field assembly).
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 957
