Ir para o conteúdo principal
Ryobi RS290G Motor Replacement
O que você precisa
    1. Ryobi RS290G Motor Replacement, Top Cap: passo 1, imagem 1 %32
      • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
      Pergunte ao FixBot
      Comentar
    2. Ryobi RS290G Motor Replacement: passo 2, imagem 1 %32
      • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
      Pergunte ao FixBot
      Comentar
    3. Ryobi RS290G Motor Replacement: passo 3, imagem 1 %32
      • Remove the top cap.
      Pergunte ao FixBot
      Comentar
    1. Ryobi RS290G Motor Replacement, Switch Trigger: passo 4, imagem 1 %32
      • Remove the switch trigger.
      Pergunte ao FixBot
      Comentar
    1. Ryobi RS290G Motor Replacement, Motor: passo 5, imagem 1 %32
      • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
      Pergunte ao FixBot
      Comentar
    2. Ryobi RS290G Motor Replacement: passo 6, imagem 1 %32
      • Remove the two 14mm Phillips #2 screws from the cord clamp.
      Pergunte ao FixBot
      Comentar
    3. Ryobi RS290G Motor Replacement: passo 7, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 7, imagem 2 %32
      • Slide the power switch out of the housing assembly.
      Pergunte ao FixBot
      Comentar
    4. Ryobi RS290G Motor Replacement: passo 8, imagem 1 %32
      • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
      Pergunte ao FixBot
      Comentar
    5. Ryobi RS290G Motor Replacement: passo 9, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 9, imagem 2 %32
      • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
      Pergunte ao FixBot
      Comentar
    6. Ryobi RS290G Motor Replacement: passo 10, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 10, imagem 2 %32
      • Slide out the brush assembly with the black lead from the inner housing assembly.
      Pergunte ao FixBot
      Comentar
    7. Ryobi RS290G Motor Replacement: passo 11, imagem 1 %32
      • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
      • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
      Pergunte ao FixBot
      Comentar
    8. Ryobi RS290G Motor Replacement: passo 12, imagem 1 %32
      • Remove the armature assembly, with the motor, out of the inner housing assembly.
      Pergunte ao FixBot
      Comentar
    9. Ryobi RS290G Motor Replacement: passo 13, imagem 1 %32 Ryobi RS290G Motor Replacement: passo 13, imagem 2 %32 Ryobi RS290G Motor Replacement: passo 13, imagem 3 %32
      • Replace the motor (also known as field assembly).
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 38
Ao todo: 1,459
