Ir para o conteúdo principal
Ryobi RS290G Bearing Cap Assembly Replacement
O que você precisa
  1. Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: passo 1, imagem 1 %32 Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: passo 1, imagem 2 %32
    • Using a TR20 Torx security screwdriver, remove the four 6mm screws.
    • Make sure to hold the backing pad firmly to prevent spinning.
  2. Ryobi RS290G Bearing Cap Assembly Replacement: passo 2, imagem 1 %32
    • After removing the backing pad, carefully pull on the rubber brake to remove it from the housing assembly.
  3. Ryobi RS290G Bearing Cap Assembly Replacement: passo 3, imagem 1 %32
    • Using a TR 20 Torx security screwdriver, remove the single 3mm screw in the center of the bearing cap assembly.
    • Make sure to use pliers or another tool to prevent the fan from spinning, and use a torque wrench or torque screwdriver as the screw is secured with Loctite (a compound to prevent it from loosening).
  4. Ryobi RS290G Bearing Cap Assembly Replacement: passo 4, imagem 1 %32
    • Remove the bearing cap.
    • You may keep the spring washer and washer for reuse if they are not worn/damaged.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 515
