Ir para o conteúdo principal
Ryobi RJ1861V Saw Bar Assembly Replacement
O que você precisa
  1. Ryobi RJ1861V Saw Bar Assembly Replacement, Saw Bar Assembly: passo 1, imagem 1 %32
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Bar Assembly Replacement: passo 2, imagem 1 %32 Ryobi RJ1861V Saw Bar Assembly Replacement: passo 2, imagem 2 %32
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Bar Assembly Replacement: passo 3, imagem 1 %32
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Bar Assembly Replacement: passo 4, imagem 1 %32
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Bar Assembly Replacement: passo 5, imagem 1 %32
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Bar Assembly Replacement: passo 6, imagem 1 %32
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Bar Assembly Replacement: passo 7, imagem 1 %32
    • Lift the assembly bar up and out of the chassis.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 885
