Ir para o conteúdo principal
Ryobi P501G Shell Replacement
O que você precisa
  1. Ryobi P501G Shell Replacement, Blade: passo 1, imagem 1 %32
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: passo 2, imagem 1 %32 Ryobi P501G Shell Replacement: passo 2, imagem 2 %32
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: passo 3, imagem 1 %32 Ryobi P501G Shell Replacement: passo 3, imagem 2 %32 Ryobi P501G Shell Replacement: passo 3, imagem 3 %32
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: passo 4, imagem 1 %32
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: passo 5, imagem 1 %32 Ryobi P501G Shell Replacement, Shell: passo 5, imagem 2 %32 Ryobi P501G Shell Replacement, Shell: passo 5, imagem 3 %32
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: passo 6, imagem 1 %32 Ryobi P501G Shell Replacement: passo 6, imagem 2 %32 Ryobi P501G Shell Replacement: passo 6, imagem 3 %32
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Conclusão
Eeshan Mishra
Membro desde: 01/24/19
424 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S1-G2, Maness Spring 2019 Membro de Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 299
