Ir para o conteúdo principal
Ryobi P235 Motor Replacement
O que você precisa
  1. Ryobi P235 Motor Replacement, Battery: passo 1, imagem 1 %32 Ryobi P235 Motor Replacement, Battery: passo 1, imagem 2 %32
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Motor Replacement: passo 2, imagem 1 %32 Ryobi P235 Motor Replacement: passo 2, imagem 2 %32
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Motor Replacement, Motor: passo 3, imagem 1 %32 Ryobi P235 Motor Replacement, Motor: passo 3, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Motor Replacement: passo 4, imagem 1 %32 Ryobi P235 Motor Replacement: passo 4, imagem 2 %32
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Motor Replacement: passo 5, imagem 1 %32 Ryobi P235 Motor Replacement: passo 5, imagem 2 %32
    • Open the housing with the data label facing up.
  6. Ryobi P235 Motor Replacement: passo 6, imagem 1 %32
    • Lift the motor and chuck assembly out of the housing.
  7. Ryobi P235 Motor Replacement: passo 7, imagem 1 %32 Ryobi P235 Motor Replacement: passo 7, imagem 2 %32
    • Remove the gear case and sleeve bearing assembly from the inner case assembly.
  8. Ryobi P235 Motor Replacement: passo 8, imagem 1 %32 Ryobi P235 Motor Replacement: passo 8, imagem 2 %32
    • Remove the cam shaft and motor assembly.
  9. Ryobi P235 Motor Replacement: passo 9, imagem 1 %32 Ryobi P235 Motor Replacement: passo 9, imagem 2 %32 Ryobi P235 Motor Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the metal pins on each side of the inner case assembly.
    • It is easiest to push the pin through the opening from one side and once enough of the pin is through, grab it with the tweezers and pull it the rest of the way through.
    • When reassembling, make sure the pin goes in straight and makes it out the other side, rather than going in diagonally and into the inner case assembly.
  10. Ryobi P235 Motor Replacement: passo 10, imagem 1 %32 Ryobi P235 Motor Replacement: passo 10, imagem 2 %32
    • Remove the ring gear.
    • To help lift the ring gear out of the inner case assembly, wedge the spudger under one side, moving it up by a little, then switch to the other side and repeat until the gear ring is out.
  11. Ryobi P235 Motor Replacement: passo 11, imagem 1 %32 Ryobi P235 Motor Replacement: passo 11, imagem 2 %32 Ryobi P235 Motor Replacement: passo 11, imagem 3 %32
    • Remove the two 8mm screws and spring washers connecting the motor to the inner case assembly.
    • Separate the two parts.
  12. Ryobi P235 Motor Replacement: passo 12, imagem 1 %32 Ryobi P235 Motor Replacement: passo 12, imagem 2 %32 Ryobi P235 Motor Replacement: passo 12, imagem 3 %32
    • Use a soldering iron to remove the black and red wires connecting the motor to the trigger assembly.
    • Use the soldering iron to connect the new motor to the trigger assembly.
    • Make sure the red wire connects to the lead with the red mark on it.
Conclusão
To reassemble your device, follow these instructions in reverse.
Uma outra pessoa concluiu este guia.
Paul Sousa
Membro desde: 10/29/19
805 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G2, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 42
Duração total: 2,007
