Ir para o conteúdo principal
Ryobi P235 Magnetic Tray Replacement
O que você precisa
  1. Ryobi P235 Magnetic Tray Replacement, Battery: passo 1, imagem 1 %32 Ryobi P235 Magnetic Tray Replacement, Battery: passo 1, imagem 2 %32
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Magnetic Tray Replacement: passo 2, imagem 1 %32 Ryobi P235 Magnetic Tray Replacement: passo 2, imagem 2 %32
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: passo 3, imagem 1 %32 Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: passo 3, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Magnetic Tray Replacement: passo 4, imagem 1 %32 Ryobi P235 Magnetic Tray Replacement: passo 4, imagem 2 %32
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Magnetic Tray Replacement: passo 5, imagem 1 %32 Ryobi P235 Magnetic Tray Replacement: passo 5, imagem 2 %32
    • Open the housing with the data label facing up.
  6. Ryobi P235 Magnetic Tray Replacement: passo 6, imagem 1 %32
    • Remove the magnetic tray from the device.
Conclusão
Paul Sousa
Membro desde: 10/29/19
805 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G2, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G2
Membros da 3
Autoria de 6 guias
Um comentário
Thanks for sharing, I was actually looking for these steps.
Mark Robert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 326
