Ir para o conteúdo principal
Ryobi P202 Bit Storage Clip Replacement
O que você precisa
  1. Ryobi P202 Bit Storage Clip Replacement, Battery: passo 1, imagem 1 %32 Ryobi P202 Bit Storage Clip Replacement, Battery: passo 1, imagem 2 %32 Ryobi P202 Bit Storage Clip Replacement, Battery: passo 1, imagem 3 %32
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Bit Storage Clip Replacement, Right Side Case: passo 2, imagem 1 %32 Ryobi P202 Bit Storage Clip Replacement, Right Side Case: passo 2, imagem 2 %32
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Bit Storage Clip Replacement: passo 3, imagem 1 %32 Ryobi P202 Bit Storage Clip Replacement: passo 3, imagem 2 %32
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Bit Storage Clip Replacement, Bit Storage Clip: passo 4, imagem 1 %32 Ryobi P202 Bit Storage Clip Replacement, Bit Storage Clip: passo 4, imagem 2 %32
    • Grip the bit-clip and gently lift up to remove it from the case.
    • The bit-clip is Part #: 630206007
Conclusão
Joseph Eckstein
Membro desde: 04/07/15
1.596 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 17-6, Forte Spring 2015 Membro de Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 427
