Introdução
If you need to replace or fix and component of the Ryobi P214 cordless drill that is on the inside cast, use this guide to access the inside panel.
O que você precisa
Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
Quase terminado!
Conclusão
