Introdução
This guide shows how to remove and replace the spray button on a Rug Doctor. The handle must be detached from the body and opened up in order to remove the button.
O que você precisa
Uncoil the power cable from the handle.
Remove the sixteen Phillips fasteners of the following lengths:
Six 22.7 mm machine screws
Four 35.3 mm machine screws
Two 25.2 mm (thicker) machine screws
Two 48.4 mm bolts with washers
Two 30.1 mm screws
Use your fingers to push the black plunger down towards the bottom of the handle into position. This may take significant force.
Once the plunger slips into position, squeeze the the two handle halves together.
If that doesn't happen, check to see if the plunger is properly positioned, and that no wires are pinched.
Continue squeezing the two handle halves together while you reinstall the handle's lower screws.
Use a pair of pliers to grasp the lip of the screw post close to the handle release lever.
While gripping the screw post, use a large flathead screwdriver to remove the machine screw mated to the other end of the screw post.
Just order Rug Doctor Complete Handle 12672 for the whole hadle assembly. This is not worth the time trying to get it off. Using taps, drill bits, vices, anything to try and hold the bald headed side stationary will still cause it to slip, and on the flat head side the channal isnt deep enough for the screw drivers causing it to easily slip and strip the head.
Use fingers or wide pliers to squeeze the black retainer tabs on each side of the button module.
While squeezing, wiggle and push the button module out of the front of the handle.
Remove the button module.
This is a terrible idea. The easy way would be to use a small flat head screw driver to pry out the switch. See where the wires go. There are two white wires on one side and a black and a red ones that go on the other. Replace the wires and fit the new switch in it's place. That's it. However, usually the wires are really short and it may be hard to get them out enough to fit them on the new one. In this case you will need to undo the strain relief at the bottom of the handle and feed it up into opening. That is the easy way out.
To reassemble your device, follow these instructions in reverse order while noting the re-assembly tips.
11 outras pessoas executaram este guia.
Include the part number of the c shaped plate.
JAMES - Responder
