Ir para o conteúdo principal
Royal Kludge GK64 Keyboard Switch Spring Replacement
O que você precisa
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: passo 1, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: passo 1, imagem 2 %32
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 2, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 2, imagem 2 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 2, imagem 3 %32
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 3, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 3, imagem 2 %32
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 4, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 4, imagem 2 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 4, imagem 3 %32
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 5, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 5, imagem 2 %32
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 6, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 6, imagem 2 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 6, imagem 3 %32
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 7, imagem 1 %32 Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 7, imagem 2 %32
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: passo 8, imagem 1 %32
    • Place the keycap back onto the switch and push down to secure the keycap.
Conclusão
Uma outra pessoa concluiu este guia.
Diksha Sakre
Membro desde: 09/19/22
228 Reputação
Autoria de 1 guia
Equipe
York University, Team A-7, Morris Fall 2022 Membro de York University, Team A-7, Morris Fall 2022
YORK-MORRIS-F22SAG7
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 356
