Introdução
Check the fuse when the current flow through the power cord, but not through the heater coil.
O que você precisa
Flip the device over so the bottom is facing up.
Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
Pry one end of the fuse from the bracket until it is separated from the holder.
Remove the fuse by lifting it up.
Quase terminado!
Conclusão
